I have a task to revise the PDF document that exist in Windchill, "revision number" need to match with the respective WT part. Here PDF/WT parts number are same.
My requirement:
I have list of all pdf document number need to be updated.
If PDF document revision matches with the WT part then "no change required" else revision need to done on PDF document.
Is it possible to automate this task
