Run IE task trough API with current logged user
smartel
6-Contributor
I'm trying to run an IE task trough a java method. But Windchill ran the task as WCadmin .
The task run fine but it retrieves info that user shouldn't have access.
If I run the IE task in the browser with the user it run fine too.
here is the code:
public static String ieTaskRun(String Task1, String Name1, String Group1, String userNa) throws WTException, IOException, IEException {
String obid1 = "";
String obType = "";
try{
IeService ieService = new IeService();
Task objtask = new Task(Task1);
objtask.setService(ieService);
//>>>> Here is where I'm trying to set username who will run the task <<<
objtask.setUsername(userNa);
String groupOutName = Group1;
objtask.setParam("name", Name1);
objtask.setParam("GROUP_OUT", Group1);
System.out.println("**** ieTaskRun Check entering task **** " + userNa);
objtask.invoke();
Group prlnks = ieService.getGroup(groupOutName);
System.out.println("ieTaskRun element: " + prlnks.getElementCount());
if (prlnks.getElementCount() > 0){
for (int p = 0; p < prlnks.getElementCount(); p++)
obid1 = (String) prlnks.getAttributeValue(p, "number");
obType = (String) prlnks.getAttributeValue(p, "type");
if (obType.equalsIgnoreCase("CAD Document")){
obid1 = obid1 + ":" + (String) prlnks.getAttributeValue(p, "version");
}else{
obid1 = obid1 + ":" + (String) prlnks.getAttributeValue(p, "revision");
System.out.println("ieTaskRun obid Task: " + obid1 + " Object Type: " + obType);
if(obType.equalsIgnoreCase("CAD Document"))
return obid1;
} catch(Exception e) {
   //e.printStackTrace(System.err);
   return obid1;
return obid1;
}//end of method ieTaskRun
smartel
6-Contributor
(To:BineshKumar1)
Thanks this has lead me to the solution.
I modified my info engine task by adding this:
Group s = getGroup ("@SERVER");
s.toXML(new java.io.PrintWriter(System.out),true);
s.setAttributeValue (0, "auth-user", userNa.getName());
userNa is a variable that is set during the info engine call.
Since that it retrieve exactly what the user is supposed to see.
wt.org.WTPrincipal user = wt.session.SessionHelper.manager.getPrincipal();
You can use sessionhelper to get the current user
Thank you
Binesh Kumar
smartel
6-Contributor
(To:BineshKumar1)
