Sending the Attribute in the change task to the Change Notice with the Alias ​​Attribute
OnurNalbantgl
Hello dear community,
I want to reflect an attribute I use in the change task to the change notice to which it is linked.
I think I should use an alias attribute for this, but when I try it I get an error.
The attribute named WORKDAY is selected in the change task and I want it to appear in the primary attribute in the change notice.
In the article on support, it is written that you should use the "wt.change2.WTChangeActivity2" method for the change task.
The MAP I tried in the Alias ​​attribute is as follows;
Fadel
22-Sapphire I
(To:OnurNalbantgl)
Fadel
22-Sapphire I
(To:OnurNalbantgl)
use below mapping :
theChangeOrder2@wt.change2.IncludedIn2~theChangeActivity2^wt.change2.WTChangeActivity2~WorkDay
CN :
CT :
Alias :
Fede
@Fadel
Your statue should be erected at the entrance of the community.
Thank you very much, great solution and explanation.
