Server manager hangs on startup, MethodServer fails to launch
Gagan
7-Bedrock
Hello All
when i entred "windchill start" in the CMD, server manager will stop at this stage and method server will never start , what could be the reason ?
BenLoosli
23-Emerald II
(To:Gagan)
Is Windchill DS started first?
Is Apache/the Web server started second?
Are your vaults enabled?
Any other log file messsages?
Gagan
7-Bedrock
(To:BenLoosli)
Hello Ben
Yes, Windchill DS started first and  Apache/the Web server started second?
how to check if vaults are enebled? i am thring to launch in my own PC
I foud a releated article for the exact same issue , but could not understand how to check in host file , i am attaching the host file here , also could not how to check cause 2 mentioned in this article?
https://www.ptc.com/en/support/article?n=CS125275
Resolution given in this article
olivierfresse
(To:Gagan)
Add some logs :
in WINDCHILL_HOME/codebase/WEB-INF/log4jServerManager.properties.
log4j.logger.wt.manager.ServerLauncher=DEBUG
and look in ServerManagers log file. Look for the command and parameters used to launch the MS
Hello olivier
Attaching  2 log files "log4jServerManager.properties" and "ServerManager-1712192006-2308-log4j"
olivierfresse
(To:Gagan)
This is strange, I don't see any logs.
It's log4jMethodServer.properties in the zip file, not log4jServerManager.properties, so...
SergeyEfimov
(To:Gagan)
Check the connection to your database.
database is conneting ,
is this the right way to check ?
SergeyEfimov
(To:Gagan)
Check the db properties and the connection by your db user.
