We have a problem in our database from windchill 12. Normally all 3D EPMDocuments shoud have a globalID(sysid) in the DB, but many of them get a "null" value now.
There is an api to get the globalid --> wt.epm.EPMDocumentMaster.getGlobalID()
this api works fine
There is also an api to set the globalid --> wt.epm.EPMDocumentMaster.setGlobalID()
this api gives me an error.
Exception:
javax.servlet.ServletException: GlobalID cannot be modified for persistent master: Assembly - CAD1000474015.sdcc |
Is there a possible solution for this? Is there a workaround for this and make the master not persistent for a few seconds until it's changed?
ps: the sysid is something from creo elements/direct modeling
