I'm a little confused on the best practices of workflows and if you can just create workflows to simply release data (with department checks).
1. Can I create a "Release" workflow and have it run on my WTparts without having it go through a CR/CN first?
2. I don't see any option to add a workflow to the dropdown on New -> <Workflow>, could I add it there or do I have to initiate the workflow from the workflow templates page
3 . What is the impact of just running it through a release workflow opposed to a CR/CN first?
I have a bunch of data that I just want to get released while going through our standard engineering checks but I don't want it to go through the engineering change notice or request because there isn't any "changes" on it yet...
Couple of options for a one-time "release" of existing data:
1. If you get all in the same search results, or browse to, select all and simple Set State.
2. Assuming the lifecycle template for all includes a valid Promotion Transition, collect all onto a single Promotion Request. Possibly would have to re-assign approval Task to yourself.
