hi guys,
I am trying to understand the significance of wt.queue.executeQueue property. We had set this property to false, when we were migrating the objects into a Windchill 10.2 M020 (Clustered Environment) server.
Earlier I was thinking that we are setting this to false, as it is a clustered environment that we are dealing with. I also thought that setting this property to false, enables only the Background Method Server to run the queues, not the foreground servers.
Now this property had been changed to true in the servers.
At this moment, I really don't know how this property works anymore. It would be much helpful, if any of you people could help me in understanding the property.
Ganesh.
I can't think of any reason why that property is true on foreground nodes. It does not make any difference in Background availability set, as this property is set to true directly in BGMS JVM startup command.
If you ever make a foreground server execute queue entries, it is going to take a toll response times the users might observe from that node.
Binesh Kumar
Barry Wehmiller
That does not sound right. wt.queue.executeQueue is the direction to foreground method servers to execute queues. In cluster none of the nodes should have this property set to true unless you wanted to have foreground method servers execute queues.
Do you have high availability queue processing configured? Still you need to have queue groups created and designate it to respective background method servers
Binesh Kumar
Barry Wehmiller
Hi Binesh,
Thanks for you reply.
Got your point, setting this property to false will not let the foreground method servers execute queues.
And to answer your question, they have some groups configured and designated to background method servers. And the server has a lot of queues configured.
Any other point about this property, that I should be aware of.
Ganesh.
Binesh Kumar
Barry Wehmiller
HI Binesh,
Thanks for clarifying that.
The property was changed when they had applied CPS08 patch. And they didnt revert it after that.
Ganesh.
