Windchillers,
If given an option; what would be more beneficial to configure ? an attribute or a soft type ?
Let us say there are 4 list available for configuration on WTDocument:
1) ID : {1,3,5,7}
2) MATERIAL : {St, Al, Br, Cu }
3) TYPE_INFO : { Decoration, Lab, commercial, Household}
4) Country : {US, FR, AU, LA}
Would it be more beneficial to configure TYPE_INFO as soft type of WTDocument and then add attributes ID, MATERIAL & Country on each soft Type (Decoration, Lab, Commercial & Houehold) ?
OR
Would it be optimal to add all the 4 as attributes on WTDocuments ?
why ?
Hi Vaibhav,
This depends on many other factors. Do you want all objects to use same life cycle template ? Are you planning to have workflows for these objects based on TYPE_INFO. Do you want a separate OIR (numbering, folder, versioning scheme)? How do you prefer to search on these objects?
If you are planning to create separate types you may want to create a particular subtype first with all the required attributes and make it un-instantiable and then create other types under this which would be marked instantiable.
Bhushan
Hi Vaibhav,
Bhushan
Hi Bhushan,
Thanks for the pointers, Very useful. Yes, We might have workflows in future; and that would be an added advantage.
However from search perspective; would the search for an ATTRIBUTE be more resource intensive than that of a TYPE ?
Vaibhav
