Stay checked-out after check-in?
gchampoux
In Windchill 9.1, after a CAD Document is checked-in, it is no longer checked-out.
In many cases, the user is checking-in to make the model availble to others, and he needs to continue working on it.
Is there a way to avoid having to check it out again?
Gerry
File>Custom Checkin
Next>Check "Keep Checked out"
[cid:image001.gif@01CC1626.24B14F30]
Steve Vinyard
Application Engineer
I DO NOT get this option on my windchill? (see attached image)
I don't have the option either. Did you ever figure this out?
pmooteri
(To:JM_LPE)
When user carries out the custom check-in, "Keep Checked out" option is available in "Edit>Keep Checked Out".
User has flexibility to select only those objects which he needs to keep checked out and apply the option.
Pankaj
