I tried to configure my windchill server for Email. but while try to run the xconfmanager i am getting the below errors,
Can anyone help me on this issue...
Did you see this case?
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS247072
Hi Jamie,
I have seen this article .but i did not used any ; for any of my passwords.
Is there any other properties to change??
Strange. The error message is exactly the same as in the case, so I would suspect it still has something to do with the encryption. How are you setting the password? Are you using: xconfmanager -s wt.mail.smtp.password=<Password> -t mail.properties -p or putting it in site.xconf and then running xconfmanager -p?
