Hi All,
Consider I have CAD document ABC--> 3.5, ABC--> 2.4 and ABC-->1.1
I need to fetch all three versions of CAD document along with representations for every version. I am using
/CADDocumens rest API and I am expanding "AllOlderVersion" service .
for ex:
expand: AllOlderVersion($select=AuthoringApplication,ID,VersionID,Name,Number,State,Version,Category,TypeIcon),Representations($filter=DefaultRepresentation eq true;$select=ID,CreoViewURL).
If I do this, I am getting representation only for the latest version. But I need representations for all the versions. How Can i achieve this ?
Hi gmydoor-2,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
This will increase your chances to receive meaningful help from other Community members.
Vivek N
Hi @vnamboodheri .. AllOlderVersion endpoint is the customized one. I have got another solution for my issue. We can use Revisions end point instead of AllOlderVersion to get representations of all versions of CAD documents.
