I was think if maybe there is a way of associate the real data to the informatios of the WTPart
like
A way to associate the mass of the Cad(asm or part) to the mass as atributes and the mass in the WTPart
like
in the table legend of drw
the scale is auto, so when we click on it, its have &SCPC_SCALE
something like that
i would like to do this with the WTParts
Someone could help me with this?
Addition: maybe even the dimmensions of the part could be auto associate to the information of the part
like
SP
This should help you to get a good understanding.
Hari
Yes, you can have a CAD variable and map it to a variable with a different name in the EPMdocument. I think that you set the mapping up in CREO. Then when you checkin the CAD and EPMdocument, you can tell Windchill to 'build' the wtPart to show the same variables. This is called bottom-up design.
This is not really 'customization' depending on how you look at it.
You can also do top down design where you start by creating wtParts, then tell Windchill to create the EPMdocuments and some empty CAD's.
Hari
