How do I assign the sub Type of the WTPart that the EPMDocument will create and associate during Checkin? One way is to use a subtype of the epmdocument itself and assign "Default part type to Create", but I dont want to take this option. Kindly pour in your thoughts.
Iam using Windchill 10.2 with Creo 2.0.
For some assemblies , when checked in, i want to create Part subtype A, while for some other assemblies I want to create Part type B.
There is a clear rule for this on what conditions Part Subtype A or B should be created, but there seems to be no direct way to specify (as an attribute ).
Are there any preferences?
Thanks & Regards
Hari Varadharajan
Are you looking for something like this?
In WC11 you can do it OOTB. In WC10.2 you need to customize it with the auto association class. There is a setting in the preference manager where you can call your own class. "Custom Class for Auto Associate Part"
