Is it possible to create a standard attribute on any WC business object without having Info Modeler installed?
--Kirk Wemple
The Type and Attribute Management content in the Windchill 10.1 Help Center includes a topic entitled "TypeAttributeMoveTool Utility"that describes how to usethis command line utility for the following:
Preeti, does this provide the information you were looking for?
Jane
Jane Zupfer
VP, Windchill Publications
T 763.957.8299
E -
I know this is a really old post, but I'm curious if you ever moved forward with converting your global attributes to standard attributes. If so, what type of performance gain did you actually realize? Thanks!
