Windchill Desktop Integration see only latest revision
SC_10041036
7-Bedrock
In Desktop Integration with Windows Explorer, is it possible to setup the system to see only the latest version of documents?
Dobi
(To:SC_10041036)
You have to set up a table view in Windchill that only displays the latest version of documents first and then use that view in your explorer. I don't think there's a way to do it through the Windows Explorer DTI interface. And honestly, even through the Windchill views, it's a bit clunky.
https://support.ptc.com/help/windchill/plus/r12.0.2.0/en/index.html#page/Windchill_Help_Center/DTIExplorerView.html
On the PTC support site there are many HUB articles that collect, in one location, those referring to a particular topic.
The one for Desktop Integration can be found here
Marco
I already had a look but didn't find my answer. I only found a post on Windchill 10. I'm on Windchill 12.0.1
Dobi
(To:SC_10041036)
