There is prospect we are working on for a global PLM project. There is a big group and multiple different companies acquired in years distributed to different locations. The aim of the global PLM deployment is the ability to share data between the different companies under the same group. However, this companies has their own ways of working and most of the times the data has to be safe and only accessible within one organization.
in order to provide that, given the fact that windchill setup suggest single organization to be implemented, what is the best practice moving forward?
do you recommend to create one organization and each product should belong to one company or do you think the different organizations should be created. if we go with the multiple organization architecture, what are the pros and cons.
can we still share change management between multiple organizations users, share data etc?
