If you have run into this, go ahead and nod in agreement (and sympathy). If you have not, and are looking to install or update Workgroup Manager software on Windows 10, be aware. In my case, seen with SolidWorks 2016/2017, Windows 10 and Windchill 10.2 M30 CPS-24:
Windchill Workgroup Manager and WFS Driver Installation fails on Windows 10 when Secure Boot function is enabled
The PTC WFS Controller service does not work properly in Windchill Workgroup Manager integration with CAD Applications supporting Windchill File System (WFS)
(disabling Secure Boot is not possible as a workaround in many organizations)
Probably other docs in the DB, but these were the ones PTC passed along. Hoping this gets a permanent fix soon!
Best Regards,
ML Starkey
Relief is on the way. CPS-25 is scheduled to drop on Sept 6th:
"The 10.2 M030 or 11.0 Windchill Workgroup Manager WFS Driver installation fails with error or the PTC WFS Controller service fails to start on Windows 10 when Secure Boot is enabled "
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS264835
Same issue with the Windchill 11.0 M030 workgroup manager.
Yes, I believe I used the patched driver until a later CPS came out. (That was a long time ago...)
Greetings @pmooteri
We've been struggling with some Windows 10 updates. currently all our Users are functioning now, but yesterday I spent the whole day fixing two who had suddenly lost access to their local 'PTC Places' folder via WGM.
I had to re-install the WGM using the CPS 13 update and repoint the local cache by editing the environment variables. It all seems to be based on a Windows 10 update, but unclear if that's really the case.
My current install is:
Windchill 11.0 M030 CPS08
WGM 11.0 M030 CPS13
Inventor Pro 2017
Windows 10
We had lots of trouble getting WGM 11.0 CPS 11 working on Windows 10 with SolidWorks 2018. We ended up having to manually add an additional environment variable. See CS295992.
