How to do mass renaming in windchill ?
In "Commonspace":
In "Workspace" (works for new objects only):
For more information, refer to : http://www.ptc.com/cs/help/windchill_hc/wc100_hc/index.jspx?id=CADxFileMenuObjRename&action=show
Hello Harshal
If all the parts are not belongs to the one assembly , is it possible to do the mass rename ?
I there any option to add those part to base line or any collector and then do the rename ? to my knowledge it is not possible even i tried any way .
If you know any method to do this please let me know .
Gagan
Yes - you can support rename from Search as well. you can search for multiple part numbers with a ; separator
Hello Jeff
I agree that we can do the multiple search by using separator , But even in the search result it is not possible to do the mass rename , am i rite?
If possible ,Could you please explain me how ?
Gagan D
Gagan Doreswamy - Rename is available from search. I forget which release it was supported in but it is available
