So these are active change objects still in process? Is there a possibility that you can keep track of them, close the workflow and resume a new workflow once the conversion is complete? Is there anything common about them that is causing an issue?
Change processes must be closed or meet other specific criteria for the flexible change conversion to work.
https://www.ptc.com/en/support/article/CS302277
Most customers close the existing change and open a new one that is flexible. Then they can convert the closed ones without issue.
The system should have been set to mixed mode back when Windchill was upgraded to 11.x. If it was and these are really long running changes, then your best option it to meet one of the acceptance criteria in that article. Given the number of them, maybe someone out there has written a customization to 'duplicate' open change objects?
If these are faster turnaround changes, then maybe set to flexible in production and give it a month for the majority of the 400 open changes to cycle through.
Thank you for your reply,
Yes it was in mixed mode and yes those were really long running changes created with custom workflows, something that i understand is pretty common for big companies.
That's why I thought that PTC would have a better solution in place than asking the client to complete all tasks..
Anyway the client decided to follow this path as the solution to write a custom readiness delegate is not guaranteed to work.
Late to the thread as I have been on vacation.
What version of Windchill were they converting from? When I did our upgrade from 12.0.2 to 13.0.2, I had to do a 12.1.2 intermediate step to get the links converted because we had old change objects from 11.0 or 11.1 hanging around. Had to go to 12.1.2 to get the required states added to the right files. They had to be added in the Type Manager UI and not from the RB files in order for the convert tool to read the information properly. They could only be added after 12.1.2 as that is where the ability to add them in the UI was added.
Hope you got everything converted okay.
Hello @Theodore_7 , I have the same issue. Can you share with us the solution, if any?
Hello @OB_8544705 ,
We have just finished the client's upgrade from 12.1. to 13.0.
Regarding the flexible objects, we just made sure everything was converted to flexible before starting the upgrade process. The solution the client followed was simply assigning an employee to manually close each one of the legacy objects so that it gets a resolution date, and then reopening the change objects. Obviously it took him a long time (a couple of months for about 500 objects).
See attached document that I created on this
