Using IE, Once Edit change task wizard opened, I am trying to close it using cancel button (Red color X button) at the top right corner of wizard. But a popup opened showing message "Denied" and I need to click 'OK' button on the popup then only wizard closed. It is not closing properly once clicked on X red colored button.
MethodServer logs showing:: "com.ptc.core.components.validators.CreateEditValidatorUtils wcadmin - DENIED - Form processing failed, but no feedback messages given"
I also called super.pre-process(); but still same issue.
Please help!!
I got the same issue, extending CreateChangeRequestFormProcessor, using a routine that does nothing but calling the parent class:
@Override
public FormResult preProcess(NmCommandBean clientData, List<ObjectBean> objectBenas) throws WTException {
logger.trace("preProcess - Inside customized routine");
FormResult myResult = super.postTransactionProcess(clientData, objectBenas);
return myResult;
get the DENIED popup window with:
TRACE : myClass wcadmin - preprocess - preprocess - Inside customized routine
ERROR : com.ptc.core.components.validators.CreateEditValidatorsUtils wcadmin - DENIED - Form processing failed, but no feedback messages given.
ERROR : com.ptc.core.components.validators.CreateEditValidatorsUtils wcadmin - DENIED - Form processing failed, but no excpetion given.
In my case, it was because I called by mistake postTransactionProcess from preprocess ...
