Hi, I have to decide my workflow path depending on an attribute type, which is having a list of values, Each value will take a separate workflow after choosing it.
I am tried to execute the below code but some how not succesful.
For Routing Two options succesfully executed, while i am using the values in place of String_value its not working.
Soft Attribute Name = CustomerGroup, Dropdown values are HERO/FORD.
if (primaryBusinessObject != null)
try
com.ptc.core.lwc.server.PersistableAdapter obj = new com.ptc.core.lwc.server.PersistableAdapter(primaryBusinessObject,null, java.util.Locale.US, new com.ptc.core.meta.common.DisplayOperationIdentifier());
obj.load("CustomerGroup");
java.lang.String string_value = (java.lang.String) obj.get("CustomerGroup");
System.out.println("Soft attibute value : " + string_value);
if ( string_value == "HERO" )
result = "Route1";
else
if( string_value == "FORD" )
result="Route3";
else
result="Route2";
catch ( Exception e )
e.printStackTrace();
Below code executed succesfully,
try
if ( string_value !=null)
result = "Route1";
else
result="Route2";
Thanks in advance.
Try .equals() or equalsIgnoreCase() to compare the values to String values and check if it helps.
string_value.equals("FORD"); string_value.equalsIgnoreCase("FORD");
Shreyas
Hi Sheyas,
Thanks for your reply, Its giving syntax error.
Thanks.
Can you share what syntax error your getting ??
Shreyas
Please find the below error,
Checking Syntax...
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression99308.java:43: error: illegal start of expression
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression99308.java:48: error: 'else' without 'if'
else if( string_value.equals("FORD"));
C:\ptc\Windchill_10.2\Windchill\temp\WfExpression99308.java:53: error: 'else' without 'if'
else
3 errors
Syntax check complete
Mahesh
Try below expression.
try
if ( string_value.equals("HERO") )
result = "Route1";
else
if( string_value.equals("FORD") )
result="Route3";
else
result="Route2";
Now, there is no syntax error, but Default "Route2" option is executing. If choose IF condition as null, throwing an error. ATTENSION: null
Mahesh
Remember that java is case sensitive, so the case statement string_value.equals("HERO") means the attribute value shas to be HERO and not Hero etc for it to work.
You can also use equalsIgnoreCase() or if(compareToIgnoreCase("HERO") == 0) ....
