Hi @GR_10587535
You need to set the Preference settings on the Organization level or Product level.
A user can not change this setting.
So you need to contact Windchill administrator to change the setting on org level or Product Manager that can set it on Product level.
Site/Organization/Product/Library -> Utilities -> Preference manager -> Create and Edit -> Allow checkout of non-latest iterations
The user setting does not allow you to change that configuration
PS> in the CS100514 case there is written that you have to go to the context configuration that means not users one.
PetrH
@GR_10587535 Hi,
Also please take care to use "As Stored" configuration when Adding those Non-latest iterations(In the Add to Workspace/Check out Window),
because if its an assembly, Windchill may only give the latest iteration of its children(Usual default behaviour), hence by using "As Stored" you will be able to retrieve the snapshot of that assembly when that Iteration was created.
Hari
