how to replace the Windchill file with local drive file
rvijaykumar
Windchill there is already the drawing with lower revision and now I have a drawing latest with revision in local drive how I can replace tat.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS57946
  • Perform the following steps:
  1. Check out the existing data to workspace
  2. Open the local data in a linked session of Creo Parametric
  3. Save the local data in the CAD application
  4. This step will overwrite the local cache for the object with the local copy and the object will now show as modified in the workspace
  5. Check in the data and the new iteration will be the local CAD Document
THANKS
