I get this error java.lang.Exception: deploy failed for (ie) with return code = 1 >
when trying to install Windchill PDMLink 11.0. on to a Windows Server 2012 Std R2 64Bt OS. Can some one help.
Ming
PTCSOLNINSTALLER_PtcInstall
LOG:
INFO 2016-05-09 16:27:30 -
INFO 2016-05-09 16:27:30 - Total time: 30 seconds
INFO 2016-05-09 16:27:30 - Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256M; support was removed in 8.0
DEBUG 2016-05-09 16:27:31 - Installation is Aborting. The installation cannot continue.
DEBUG 2016-05-09 16:27:31 - 正在中止安裝。 無法再繼續安裝。
FATAL 2016-05-09 16:30:32 - Aborting installation.
FATAL 2016-05-09 16:30:32 - 正在中止安裝。 無法再繼續安裝。
FATAL 2016-05-09 16:30:32 - java.lang.Exception: deploy failed for (ie) with return code = 1
FATAL 2016-05-09 16:30:32 - aborting: original exit_code = 2
FATAL 2016-05-09 16:30:32 - aborting: normalized exit_code = 2
DEBUG 2016-05-09 16:30:32 - SHUTDOWN REQUESTED
DEBUG 2016-05-09 16:30:32 - (X) commiting registry
DEBUG 2016-05-09 16:30:33 - (X) shutting down service manager
DEBUG 2016-05-09 16:30:34 - (X) cleaning up temporary directories
DEBUG 2016-05-09 16:30:34 - Exiting with exit code: 2
DEBUG 2016-05-09 16:30:34 - java.lang.NullPointerException
DEBUG 2016-05-09 16:30:35 - cleanUp()
DEBUG 2016-05-09 16:30:35 - calling cleanUpWin32()
This does not have enough information on why it failed. Could you attach the complete PSI log and IE_installer logs from Windchill/Installer/logs directory?
It looks like the LDAPServer/WindchillDS was down when you ran the PSI. Start the WindchillDS and run PSI in recover option
Ming,
Were you able to get Windchill installed after starting WindchillDS, as suggested by Binesh? Let us know if you're still having any trouble with the installation.
