pdm Essentials -I want to change a part in an assembly with an existing in Commonspace(windchill cabinets)
mamobono
6-Contributor
problem
in the workspace with INTRALINK 3.4 command duplicates, I create new assembly and then I duplicate the particular (with true flag) to be changed giving it the same name as the existing part in Commonspace
Update the part in the workspace
I correct the new assembly and its drw
done
how can I do the same with pdmEssentials
TY
Hello.
Save As allows this functionality.
If you want to be able to replace with the content in the Commonspace, then you can enable the Replace action.
  • Login as Admin
  • Go to site > Utilities > Preference Management.
  • In Preference Management go to Save As section and set "Allow Replace" to Yes.
  • This will enable a replace action in the Save As UI:
  • Note: This action (like ProI 3.x) will only update parents that are either
    • being copied
    • or set to be updated on the Update Parents step (see my other post to you on Update Parents)
Jennifer
thanks for the reply
