report builder model creation (Windchill 11)
PD_8914712
hello
i  would like to add object history into selection/constraint ?
Ex : Change History
Please can you change the browser language to English, because it is impossible for you not to have the last modification date since it is a STANDARD attribute of Windchill.
Then, having done that, verify that the table you put in the report is the correct one.
In my case it has this internal name wt.lifecycle.ObjectHistory
Having done that I wouldn't know what else to suggest.
Marco
7 REPLIES 7
PD_8914712
(To:Marco_Tosin)
Hello Marco
I suppose, i have not selected the good attribute
but i have not found an attribute named « promoted date »
please see attachments
You have selected the state not the date.
Try the attribute highlighted in yellow
Marco
PD_8914712
(To:Marco_Tosin)
Marco
you say I have selected the state not the date
where do you see that ? here down it  seems i have selected history.modifyTimestamp
i tried to select History.Last modified but i can't find it
You have to select this table
And this attribute
Marco
PD_8914712
(To:Marco_Tosin)
Hello Marco
your response is clear but as i said upper i can't find "Last modified" into my Object History
Marco
