I have a small windchill installation for about 20 mechanical engineers and i have 2 cadworkers. We still use manual ECO's where the Doc control ladies open the affected parts with creo view and print a pdf of each one, then attach them to an email for approval (welcome to 1997 :-)). I'm trying to convince them that we should use windchill for ECO routing but they say Windchill has issues and they don't want to do it.
one issue holding us back is about twice a month somebody triggers hundreds or thousands of publish jobs. My poor cadworkers crunch for hours and the Doc control ladies have to wait hours to manually publish the new parts so they can open them in productview.
I found CS28472 which says you can elevate manually published stuff to the High Queue with this setting
<property name="publish.publishqueue.priorities.1.1" overridable="true"</p">
targetFile="codebase/wvs.properties"
value="H"/>
Great, so i tried that and restarted windchill. The problem is that whoever trigered the 2,500 publish jobs did it manually, so that all went in the High Queue as well.
Has anyone else had this issue? how did you solve it?
CS28472 says Note: There is currently no way to change the priorities of individual jobs manually, or to set priorities per user. However, an alternate technique may be to log in as a site administrator to access the numbered PublisherQueue entries, then suspend lower priority jobs that are ahead in the queue.
is the manual suspending of the jobs my only recourse?
thanks
adam
ps, here's my High Queue haiku
Doc control ladies
Cling to old technology
You will have to wait
