wt.query.QueryException: The index specified does not reference a valid expression in the SQL FROM clause
kguilloud-2
Hello all,
When i want to perform a search in Windchill PDM Link (v8), i have this error for one user :
StackTrace in attachment
The error message indicates that Windchill is trying to generate a SQL query, but there is a problem with the query. The stack trace indicates that the error is coming from an InfoEngine task. Do you know what IE task is causing the error? Is this a custom IE task?
I don't have any response.
Nobody can help me ?
