Is anyone successfully using a .rcp file to dummy down data for export?
DavidFrancis
I am having no success at using a .rcp fle to export geometry to a .pvz file that is not manufacturable or revere engineerable?
Any insights?
David T. Francis
mbarrows
(To:DavidFrancis)
I see this problem has been around for a long time!
I'm trying to get Creo to export parts with combination views and annotations so that I open and see them in Creo view express lite. The aim will be to replace the drawing environment. So far all I'm getting is that we have to go onto maintenance to run the free software the way we want it.
mbarrows
(To:mbarrows)
I've been successful with getting my combination files in Creo View Express.
One you need to set the intf_out_pvs_recipe_file in the configuration editor to a directory which you can edit.
You then copy export_pvs.rcp into that directory
You then open it in Notepad and add in
adapter/convAllStates = 1
If you now save your file as a PVS or PVZ file it includes all the Combination Views under the viewable tab.
I've also included
adapter/simplifiedReps=1
Currently I'm not getting my simplified reps to work well with a combination view. In fact I'm not convinced this adapter made any different at all. Which kind of defeat the purpose!? As what I really wanted to show in the factory was the different simplified reps.
Anyone which found a solution on this? I need to show both the combination of the Orientation and the Simplified Rep.
mbarrows
(To:mbarrows)
Hi just an updated - I've worked through all the adapters in my recipe file and this is what I've ended up with. I didn't check for sxec views or in assemblies. This is purely for parts with several combination views. I've also not got the simplified reps working yet.
file=proepview-rcp
ver=5
*/ This influence the visibilitiy of annotations
adapter/outputAnnotPlanar=1
/* This adds a list of the Combination views under Orientation if =1
adapter/convViews=0
*/ These adds a list of the COMBINATION views under Viewables if = one
adapter/outputAuthorState=1
adapter/convAllStates=1
