Creating PV files with custom check in
JoeFrancz
Most of the time we just let the cad worker do our publishing. For our top level drawings we usually do a custome check in and select "models & viewables" at the check in screen. Most of the time the drawing gets checked in with no problems. We do this for the top levels to take some of the publishing load off the cad worker. We do have some drawings that just wont go thru the custom checkin process and the viewable never gets published (publishing queue shows they failed). I am looking for some tips on how to do a successful custom checkin of large drawings.
We are using WC 9.0 m060 and WF4 M210
TIA
Would increase of memory for the worker be a solution ? Our worker has as much mem. as our Cad stations do have.
