Has anyone implimented Creo View 3? In sectining, you do a "Show 2D View" and the 3D & 2D views are side by side. Once you close the 2D view, the 3D view still stays half screen and there is no way to make it full screen again.
You have to close out of Creo View and then open it back upor add a new file to a new session from PDM Link.
Has anyone else seen this behavior. Opening a defect with PTC.
Lance
