Creo 3: IDF (EMN/EMP) Question to why Assembly not Saving with a Part from Library
amorales
I am changing from Creo Elements Pro to Creo 3. I am recently testing the IDF process. In the assembly we have the ECAD Hint going to our component library. After running the EMN and EMP and getting a assembly of a PCB.
I now try to save the assembly it does not save and it stops at a part in the library (for my test I saved as a C3 part with Family table) which does not save my whole assembly. If I open up the part and save with family tables and go back to my PCB it now saves.
The issue is in my test environment I only kept 2 library parts. But in a normal condition we would have over 2K of parts.
Is there a configuration option that I may have missed from CEP to C3 that help save parts or something else?
Best regards and appreciate any information on this.
The fix to the issue that I outlined above was a configuration setting. I had save_instance_accelerator set to always. Which prevented from saving. I changed to NONE and it fixed the issue with WC and Creo saving these assemblies and parts with family tables. It solved my issue.
