I have 2 users, on different shifts, that need to use the same computer.
bclaerhout
3-Visitor
I have 2 users, on different shifts, that need to use the same computer. An error/warning pops up when attempting to register the server for the second user. It is regarding the cache being registered to another user.
What do I need to do to allow multiple users on one computer and not affect the other users workspaces?
This can be controlled using the following environment variables depending on whether you are using Creo or a 3rd part CAD app:
PTC_WF_CACHE
PTC_WF_ROOT
PTC_WLD_ROOT
Make sure when you define these variables that you use the username in there eg PTC_WF_CACHE = c:\windchill\%username%
That way whoever logs on will create their cache in a unique area
PTC_WF_CACHE
PTC_WF_ROOT
PTC_WLD_ROOT
Simon,
Thanks for the tip.
I used your %username% idea at the end of all the .psf files in the ....parametric\bin directory
ENV=PTC_WF_ROOT=C:\WINDCHILL_CACHE\%username%
Best regards,
Bryan
