Is pro e 5 compatible with windows 8.1? Clicking on setup file does not show up anything!!
Manish Papreja
Manish,
Wildfire 5.0 is not supported on Windows 8.1, Creo 2.0 M100 and later are supported on Windows 8.1. For Wildfire 5.0 try executing setup.exe using > Right Click > Run an admin, not sure it will start installation or not, however you can make a trial.
Manish,
you can copy Wildfire 5.0 installation from another PC to Windows 8.1 PC and test if it runs.
Martin Hanak
Dear Martin,
Thanks for the suggestion. Should be a good solution if it works but I don't know how to copy installation from one pc to another. I have another PC having Windows 7 32 bit where wildifire 5. is working fine and my target PC is having windows 8.1 64 bit. Could u please guide me in trying the suggested option?
Manish
Manish,
Dear Martin,
Could u please guide me in trying the suggested option?Manish
How to ProE WF5 installation from W7 to W8.1:
Martin Hanak
