Query WTPart using SUBTYPE NAME
hmungekar
I previously queried WTPart using subtype reference:-
TypeDefinitionReference typeDefRef = TypedUtility.getTypeDefinitionReference("subtypename"));
sc = new SearchCondition(WTPart.class, "typeDefinitionReference.key.id", SearchCondition.EQUAL, typeDefRef.getKey().getId());
however i now have a requirement to query this using subtype name directy as in:-
sc = new SearchCondition(WTPart.class, ----- WTPart.Subtype ------, .......);
is it possible?
Yes, it is possible. Try the following piece of code:
final public static IdentifierFactory IDENTIFIER_FACTORY = (IdentifierFactory) DefaultServiceProvider.getService(IdentifierFactory.class, "logical");
TypeIdentifier tid = (TypeIdentifier) IDENTIFIER_FACTORY.get("WCTYPE|wt.doc.WTDocument|com.ptc.ReferenceDocument");
QuerySpec qs = new QuerySpec();
int idx = qs.addClassList(WTDocument.class, true);
SearchCondition sc = TypedUtilityServiceHelper.service.getSearchCondition(tid, true);
qs.appendWhere(sc, new int[] { idx });
qs.appendAnd();
int index = 0;
qs.appendWhere(new SearchCondition(WTDocument.class, Iterated.LATEST_ITERATION, SearchCondition.IS_TRUE), new int[] { index });
QueryResult qr = PersistenceHelper.manager.find((StatementSpec) qs);
Thanks for the reply
but my problem is because of migration i am getting some duplicate values of id for a single subtype
I hence want to completly base the search on subtype name only and dont want to use TypeIdentifier at all
