I am attaching STEP and IGS files as a primary content to WTDocument. I want to generate the representations.
I have added.
worker..DWG=DUMMY,preconverted=true
worker..TIF=DUMMY,preconverted=true
worker..BMP=DUMMY,preconverted=true
worker..PDF=DUMMY,preconverted=true
worker..STEP=DUMMY,preconverted=true
worker..IGS=DUMMY,preconverted=true
in wvs.properties file.
but not working.
please suggest.
Simply creating these properties doesn't make the files automatically show up. They still need to be run through the publisher after these properties are created.
Here is the exact syntax I used for our 10.2 system:
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..DWG=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..DXF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..PDF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..BMP=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..JPG=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..TIF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..GIF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..PVZ=DUMMY,type=zip,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..EDZ=DUMMY,type=zip,preconverted=true
xconfmanager -p
xconfmanager -p
Its working now. There was problem with object adapter.
