Flat view Annotation 18.1 - 19
IF
does anyone know help me? I customized lines of geometry from yellow to white, but the flat view is displayed white.
I do not find a way to customize it ...
whofer
8-Gravel
(To:IF)
Do you use basic sheet or SheetMetal?
If you use SheetMetal you have to change the file sha_demoshop.lsp
If you use basic sheet you have to change the file sd_data.lsp because the only way is to change the persitant data.
In this file you will find a section like this:
(persistent-data
:key "BASIC-SHEET-METAL-SHOP"
:value '( :DEFAULT-MATERIAL-THICKNESS 1 :DEFAULT-BEND-PROCESS "bends"
           :DEFAULT-BEND-RADIUS 1 :DEFAULT-RELIEF-TYPE "rect_relief"
           :DEFAULT-RELIEF-TOOL ( :WIDTH 1 ) :DEFAULT-MITER-RELIEF-TYPE
           "miter_chamfer" :DEFAULT-MITER-RELIEF-TOOL ( :PERCT_DEPTH 100 )
           :DEFAULT-RELIEF-DEPTH 0 :DEFAULT-CORNER-RELIEF-TYPE
           "min_perp_v_corner_relief" :DEFAULT-CORNER-RELIEF-TOOL ( :MIN_WIDTH 1 )
           :DEFAULT-CORNER-GAP 0.1 :DEFAULT-CHECK-PART T :DEFAULT-KEEP-WP NIL
           :MATERIALS ( ( 0.5 ) ( 1 ) ( 1.25 ) ( 1.5 ) ( 2 ) ( 3 ) ( 5 ) ) :BENDS ( ( 0.4 ) ( 0.6 ) ( 0.8 ) ( 1 ) ( 1.5 ) ( 2 ) (
           2.3999999999999999 ) ) :RECT-RELIEFS ( ( 0.01 ) ( 1 ) ( 1.6000000000000001 ) ( 2 ) ( 3 ) ( 10 ) ( 20 ) )
           :K-FACTOR 0.4 :SHOP-UNITS ( 1 :MM ) :DEFAULT-CORNER-LONG-LIP-OFFSET 0
           :DEFAULT-CORNER-CONSTELLATION :SYMMETRIC :SHARP-BEND-RADIUS 0.4
           :FLAT-DEFAULT-COLOR 16777215 :FLAT-FOLD-UP-COLOR 65535
           :FLAT-FOLD-DOWN-COLOR 65535 :FLAT-TOOL-COLOR 65280 :FLAT-ERROR-COLOR
           16711680 :FLAT-FOLD-UP-LINETYPE 0 :FLAT-FOLD-DOWN-LINETYPE 1
           :FLAT-TEXT-SIZE 3.5 :FLAT-DEFAULT-LINEWIDTH 0 :FLAT-TOOL-LINEWIDTH 0
           :FLAT-ERROR-LINEWIDTH 0 :FLAT-FOLD-UP-LINEWIDTH 0
           :FLAT-FOLD-DOWN-LINEWIDTH 0 :FLAT-SHOW-LABELS T
           :FLAT-SHOW-REFERENCE-POINT T :FLAT-WORKPLANE-OFFSET 0 :FLAT-PART-NAME
           "sha-flat" :FLAT-TRIM-BEND-LINES T :FLAT-SINGLE-BEND-TEXT NIL
           :SHOW-MERGEABLE-LINES NIL ) )
And here you can change all the available entries.
Best regards
Wolfgang
