Help in creating parting line
amitshah
Can anyone help me in creating parting line for the attached component.
I could not able to do so.
Thanks in Advance
Amit
Inoram
(To:amitshah)
It seems like the worst spots are the transition from the end diameters to the main body. You can try to tweak those a bit.
Well it aint flat if that's what you want. I rotated the part so the center section is vertical and you can put the P/L where ever you want in that area. The rest really aint bad, do the silhouette curve and then the areas where it dont match 100% just do a projection in that area to smooth it out. Then copy each side as 1 curve and away ya go with a split.
Have fun.
Hi Gary,
I tried hard to create a silhouette curve but withouot success. Is there any way to easily create silhouette curve.
Inoram
(To:amitshah)
Which way are you trying to orientate it? And which part are you having trouble with?
