Creo View 3.0 M030 with Internet Explorer (IE) 11
bwilcox
Does anyone know how to force Creo View to use Document Mode 8 with Internet Explorer 11? We are running Windchill 10.1 M050, Creo Parametric 2.0 M140 and Creo View 3.0 M030. According to the PTC literature, all of these versions should be compatible with IE 11. We had to force Windchill to load in Document Mode 8 in order to get it to work. We are having an issue with Creo View, however, where it will not load CAD drawing or other images because its default IE document mode is 5. When using F12 to go to developer mode, we can manually change the document mode to 8 and then the image loads properly; however, as soon as a new Creo View session is loaded, the document mode defaults back to 5 and won't work again.
Any ideas how to force Creo View to always use document mode 8 with IE 11?
Our IT department was able to resolve this issue. I am not entirely sure what they did to fix it, but we are now up and running properly.
