Simulation of an assembly - How to see the stress of each parts ??
oflou
Hello all,
I make a simulation of an assembly and when i see the stress results (von mises) it only shows the global values.
Is it possible to have the stress results of each parts ??
Thanks for your help
Olivier
Chris3
20-Turquoise
(To:oflou)
In the result definition window, click the display location tab and then select components and use the buttons at the bottom to hide or show them. This will allow you to isolate individual components.
Chris3
20-Turquoise
(To:oflou)
oflou
(To:Chris3)
Thank you Christopher,
That's exactly what i want ...
