failed to launch server connection error mathcad 15
dsherwood
I receive the message "Failed to launch server connection" in Mathcad 15 all of a sudden.  What can be done?
RichardJ
(To:dsherwood)
What type of licensing do you have?
Thanks Richard.  I have a single user license.  I have not tried to repair the installation; I don't know how but would like to give it a whirl.  I will boot up the machine Mathcad 15 is on if you need the license number.  I have been using Mathcad since version 2.5, 1988, if I'm not mistaken.  Thanks again Richard.
David
(509) 205-8367
RichardJ
(To:dsherwood)
Go to "Control Panel", and select "Programs and Features". If you select Mathcad you will get an option to repair the installation.
That worked.  Thank you very much Richard!
