Windchill 8.0 : bug in Query Builder ?
spassager
Hye,
I have a report to do with Query Builder .
However, I can not see objects that I created , but I can see others already existing .
Can you tell me if there is a parameter or attribute to specify in modeling statement or a properties file to update ?
Thank you for your help.
Sebastien
Sébastien,
take a look at this document Resource for reporting
In it you can also find, as an attachment, a very old presentation from PTC, but still the most complete, about reporting.
Marco
Marco,
Thank you for your answer.
Unfortunaly, I don't have access to the support ptc documents.
And I didn't see anythink on the customize objects...
Yes, I downloaded these documents, but there's nothing about new customize objects.
Try to post your request in this more specialized group Windchill Customization
Hope it can help you
Marco
I post it !
Thanks for your help Marco Tosin.
