how to create a gtol in drawing
xd
how to create a gtol in drawing mode?
can anyone help? or share some codes?
i did it with protoolkit, however, it does not work right. Maybe the annotation plane or the placement is set wrong.
xd
(To:xd)
procedure is as follows,
check ProGtoldataStatus step by step,
it's a little complex, the reference , the model, the type and the placement have relations to each other.
ProGtoldataAlloc(drawing,&gtd);
ProGtoldataModelSet(gtd,solid,&gtds);
ProGtoldataTypeSet(gtd,type,&gtds);
ProGtoldataReferenceSet(gtd,rtype,reference,&gtds);
ProGtoldataPlacementSet(gtd,ptype,NULL,NULL,location,NULL,&gtds);
ProGtoldataPlaneSet(gtd,&plane);
ProGtoldataGtoldatumrefSet(gtd,NULL,NULL,NULL,&gtds);
ProGtoldataDiameterSet(gtd,diameter,&gtds);
ProGtoldataValueSet(gtd,b_v,d_v,name,&gtds);
ProGtoldataMatCondSet(gtd,matcond,&gtds);
ProGtolCreate(gtd,&gtol);
ProGtoldataFree(&gtd);
xd
(To:xd)
