Cratered Surface
John.Pryal
Cratered Surface
Hi all, i have received an igs model which i am being asked to reproduce in Creo 3. The model contains some very rough bumped up surfaces, you might describe as 'cratered', like the surface of the moon, so to speak. These surfaces are actual surfaces, not just texture applied to the surface for rendering purposes. This is something i have been asked in the past, but i have always shied away from, stating it can't be done with pro-e/creo software. I ask this forum again, in the hope that something may have changed. Can a surfacfffe texture like this be modeled in Creo (quickly)? In the past, it was suggested using the old 'free form surface manipulation' found under 'Tweak Surfaces', but this would be far too time consuming, and i could never get the desired results when i tried it. Just out of curiosity, does anyone have any suggests as to what software might have created such a surface in the first place.
There is also the possibility of using the 'Warp' feature & sculpt i suppose, but again, very time consuming & very difficult to achieve the desired result.
John
16 REPLIES 16
TomU
(To:John.Pryal)
I'm curious too...
I ran into this once on a baffle inside a muffler.  I believe the surface was created in Catia and it was very, very heavy to work with.  I ended up just copying the surface and merging it with other ones created in Pro/e.
kdirth
20-Turquoise
(To:TomU)
I would agree that the easiest way would be to use the IGES surface to create the surface in a CREO file.  (Use Solidify to cut or create solid)
John.Pryal
(To:kdirth)
Thank you for the swift replies. Sadly, it isn't that easy. When I said I had to reproduce the model sent, I was been economical with the true. It not the model I need to copy, but the surface type, i.e. a cratered effect. The model I have to create is a totally different shape to the igs model I have, that was sent for reference only.
What I was hoping for, was to make a plain model, then pick a surface set & apply a deformation in the same way you might apply texture to a surface using the appearance manager.
John
John,
If I am not mistaken you are looking at an IGES that is the result of a paint crinkled, skinned clay model that has been scanned with an white light scanner. It looks like orange peel in the paint work. It also looks like you have zoomed up pretty tightly on the surfaces.
The answer is: If you actually "need" that surface then you have to use it as is. There is no way to get that in the data with native features in Creo. A while ago NX (old UG) had a function called "Drape" that was neat. It would interpolate and "simplify" a native UG surface over a noisy scan. You may want to hit up an NX forum and ask if they still have it.
That is my best guess.
Thanks for the reply. Actually, that screen shot was barely zoomed (at most 2:1). I cannot be certain, but I think this surface has been produced with software. My customer has asked for a plain model & they will pass it on to some design agency who will apply the 'crater' effect at a later date. I did not think this could be done in Creo, but it was worth asking, if just to find out how it could be done.
John
Did you try Surface Edit tool inside Style feature? If you have single patch surface - it can provide you high level of details
in editing the surface.
John.Pryal
(To:mshtein)
Thanks Michael, unfortunately, I don't have Style feature licence.
John
The program you're looking for is Delcam Powershape
Delcam PowerSHAPE: Adding Textures - YouTube
Thanks for the info. We have PowerShape here. I just showed the video clip to our PowerShape guys, & they almost had a heart attack! I joked that they would have to do the job. Again, just as with Creo, they claim you need some advanced surface licence to do this, which they don't have, or are they BS ing me?
John
The way these software companies like to nickel and dime customers these days, I wouldn't be surprised if it costs extra.
All I know is that it can do what you need. You can always try to request a demo from your sales rep or reseller.
When I saw a demo of this, it didn't look too difficult - just import and wrap it on the surface.
Sounds like you need some motivational exercises in your office. If your Powershape boys are too afraid to do this, maybe you should take them out for some confidence building- hiking, climbing, arm wrestling, a meal involving red meat, hand to hand combat, etc. Not knowing is not a problem. We know that we don't know, no surprise there. Fear is the only darkness
Greg,
Are you sure you read the original question correctly? John said he needed to model the surface shown natively, not simply mill it. I looked at the Delcam site and did not see a set of canned textures in the CAM/Electrode features that could be applied to a surface. Maybe I missed it on their site?
I read his question and understood what he was saying:
"What I was hoping for, was to make a plain model, then pick a surface set & apply a deformation in the same way you might apply texture to a surface using the appearance manager."
He would need to take his IGES and save it as an STL mesh, which would be "wrapped" the texture onto a surface in powershape.
In fact, John already came up with the answer himself. He took his experience with appearances, surfaces, and mapping textures and, through inductive reasoning, deduced that there should be way to map geometry in a similar way.
While the powershape users in his office with their eyes closed are listening to the things they always listen to with eyes open, John is making new mental connections and synthesizing new things and finding grasshoppers that weren't even noticed with eyes open.
Even though he didn't know how to do it, he still knew it could be done. This is an example of taking the entropy of uncertainty and confusion, and repurposing it into something useful. Decision and creation methods like his are how software like Creo is mastered.
The old knock on Creo (Pro/E) is that it's too complicated with too many steps, menu picks, mouse movements, etc. The real problem is that it constantly requires a cycle of:
learning the basics, unstructuring those basics in order to separate what's useful from the noise, establishing a mental map into something productive, and then destroying that mental map while extracting the useful elements
over and over and over. Most people get hung up on one of the first three steps. Only the select few can consistently accomplish the last.
Whoa...my brain hurts after reading that.
An stl would never be able to produce that texture in any useable way. The resolution required would be immense. Also, the file would be so data heavy that the machine trying to deal with it would crap out. To me, that image seems to be the IGES result of a high resolution scan.
What I asked was if Delcam has that canned texture tool in it's tool box that allows that random texture to be added to the mold/die as a CAD/CAM native feature. (I.E. a surface that could be exported back to out). I briefly looked at their site and did not see anything that indicated it could do that. Typically that type of texture is "applied" to the actual physical tooling surface by some means (Chemical etching, bead blasting, etc...)
I am all for learning something new so if Delcam has that I would like to know. I have to specify texture on many of the parts I create.
Look into getting some new hardware. This type of thing is done all the time.
I checked my notes and remembered that we ended up getting this work done with the mold maker. They used these two:
Magics, the Most Powerful STL Editor | Software for additive manufacturing
http://www.geomagic.com/en/products-landing-pages/re-designx-wrap
If you don't like STL then Geomagic will work with STEP or IGES
I can't tell what the scale is on John's image. If it's super fine detail then yes, they're going to use etching or electro-deposition or  Mold Tech textures
Inoram
(To:John.Pryal)
You may have moved past this issue by now. But I am still curious. How big would one of those craters be? And does it have to be 100% random or can there be some symmetry?
John.Pryal
(To:Inoram)
Hi Matt, looking at the model I was sent, I would say the maximum depth of crater was 2mm, & the pattern looks totally random. I spent a little time looking to see if the pattern was repeated & as far as I could see, it is not.
Greg, thanks for your thought provoking replies, I'm not sure our PowerShape guys appreciated them as much as I did ha ha. To answer your query, I would suggest the scale of the image I initially posted, to be approximately 2:1
John
