We have a number of wtDocuments that require "No Content" & others that require a template to be selected. Our users continually make the mistake of not selecting the template, and complain why we can't make "No Content" as a default for documents.
Looks like I was able to do this by modifying the documentManagement.js file.
Hello Tim,
I believe I have done this before. Let me go through my archived emails and I will share steps with you.
Shirish
Hi Tim,
Wanted to confirm which Windchill release & datecode you are using so I can validate the steps for this perticular release.
Additionally are you also looking for a way to hide "Local File" option from drop down list?
Best Regards,
Shirish
Hi Tim,
You can also achieve this using JavaScript. For an example, you can below JavaScript function in "<WT_HOME>\codebase\netmarkets\jsp\document\create.jspf":
<script language="JavaScript">
PTC.driverAttributes.on("afterRefresh",function() {
setTimeout(function(){ customPrimaryContent(); }, 100);
function customPrimaryContent(){
var element = document.getElementById("createType").value;
var desiredDoc = "wt.doc.WTDocument";
var list = document.getElementsByName('___primary0contentSourceList___combobox');
var fileInput = document.getElementById("primaryFileWidgets");
if(element.toLowerCase() === desiredDoc.toLowerCase()) {
list[0].selectedIndex = 0;
fileInput.style.display = "none";
} else {
list[0].selectedIndex = 1;
fileInput.style.display = "initial";
</script>
By doing this I am able to make "No Content" to Document type. See below:
Shirish
