Anyone else run into this problem? In WF4, we were able to generate the NWF file, import it into a harness and autoroute cables.
Since we upgraded to CREO 2.0 that functionality stopped working for us. It'll autoroute wires thru defined networks fine, but
it ignores cables. If you have a solution/work around I'd be interested in trying it.
Thank you
One thing I found in our internal database (routing cables from NWF logics failing in Creo, when it worked in Wildfire 4.0), was with Minimum Bend Radius.
In that case the routing failed due to Bend Radius Violation in Creo, while Wildfire 4.0 somehow allowed it.
If this is not the reason for your issue, I recommend opening a case with technical Support.
Hi Abel,
Could you fix the issue?
I'm lookin to use NWF logics to auto route some cables but i can't, could you help me?
Thanks in advance
Ruben,
PTC agreed we they had an issue. Wednesday 8-5-2015 they called me to show me the fix(es), however you will have to wait until M180 is shipped. Mid late September. This also corrected the crash issue if you happen to pick on the model tree.
Jay Dorval
