static stresses analysis on welded assembly can it be done?
selmakayes
Hi
1. On general, can static stress analysis can be done on assembly ?
2. i have a sheet metal assembly made of 2 (8mm thick) sheet metal parts, ther are assembeled by grooves and welding
i have added a welding by using the "application" featur assuming that this way i could do a static stress analysis on assembeld parts, but i dont know if CREO conceder it as an actually welded parts as in real and do the correct sterss analysis
- Is this a way to do it?
- regardless the last question, what is the best methode to do a static stress analysis to a welded assembly or any other assembly that used  by screws (i most mean to welding, since screws and oter mechanical connecting fasteners can be simulated) ?
thx
Shay
In response to 1, yes, it's entirely possibly to run analyses on an assembly.  Make sure that you set each 'interface' (coincident surfaces) between the parts appropriately: free, bonded or contact.  You can set a default interface for the model; and you can then over-ride that by creating individual interfaces between pairs of surfaces.
For question number 2 it seems there is a new thread here Stress analysis simulation on welded parts
I wrote a few words on weld analysis here:
Re: How are others calculating Welds in Creo Simulate?
