How to extract pieces of strings to assign to a parameter
abesau
2-Guest
I need help extracting a string from a system parameter to assign it to a user defined parameter.
Any help would be greatly appreciated.  Please see attached where I explain better what I'm trying
to accomplish.
Update: been trying and it doesn't like system parameters such as model_name.  I can use any other user defined
parameter and it works fine.
TomD.inPDX
17-Peridot
(To:abesau)
In the case where the filename length is not fixed, you will have to use the if/else/endif solution to test the last character until you find a underscore or period.
Here is an extensive use-case...  see the 1st comment below the document
Architectural Dimension Converter: Creo 2.0 + references
TomD.inPDX
17-Peridot
(To:abesau)
If I understand what you are asking, you are also having trouble making the model_name parameter into relations.
This is the trick to make the current model name a relation.  This can be manipulated to extract the substring.
The text string in the graphics window is &mypart in annotation.
Excellent!  Thanks for your help TomD.inPDX, Got me going in the right direction.
Here's the relation that worked for now:
part_number=(rel_model_name)
part_number=extract(part_number,1,9)
RESULTS IN:
part_number = AA-00-910 (this is good)
But what happens when the part number has more than nine characters?
For example, now I have an assembly where the model_name = AA-00-1234_route.asm
If I use the above expression:
would yield:
part_number = AA-00-123 (truncating the part number, it will leave out the number "4" resulting in an incorrect part_number.
TomD.inPDX
17-Peridot
(To:abesau)
Chris3
20-Turquoise
(To:abesau)
If you want to clip at an underscore, you could use something like this:
part_number = extract(rel_model_name,1,search(extract(rel_model_name,1,string_length(rel_model_name)),"_")-1)
For your example above, AA-00-1234_route.asm will become AA-00-1234
Thanks Christopher.  I'll try that too.
TomD.inPDX
17-Peridot
(To:Chris3)
That's a great tip, Christopher!  Thanks.
