Query in regards to a BOM in a Creo drawing
psimha
I have a Creo 2.0 drawing in which a BOM is defined for an assembly. The BOM has components stated from Sl# 01 to Sl# 20. We need to change the serial numbering now from Sl# 600 to SL# 620 for the same drawing.
Is there any way of acheiving this. Request you to revert.
Best regards,
Simha
psimha
(To:psimha)
Please note that, the BOM generated is an auto generated BOM and is not a manually entered BOM.
10 REPLIES 10
psimha
(To:psimha)
TomD.inPDX
17-Peridot
(To:psimha)
You probably need to create a custom repeat region where you convert the find number by adding 600 (if numeric) or prefixing a 6 (if string).
You can always make a simple table that does not auto-populate.  I still find this easier in most cases.
Hello Antonius,
Thanks for your reply. If you can quicky attach the steps that are to be followed, it would be of a great help.
TomD.inPDX
17-Peridot
(To:psimha)
I was able to simply prefix the variable with the number 6...  Highlight the first cell, right click, and select properties.
The dialog in the image should show up.  Add the 6  before the &rpt.index.
I suspect this will be problematic when it reaches 2 digits.  Beyond this tip, I am not familiar enough to guide you through more advanced means of using repeat regions.
Hi Antonius,
Thanks a ton.
Best regards,
Simha
Dale_Rosema
(To:psimha)
If that answered your question, don't forget to mark it as correct for those that read the thread in the future. (Actually - Antonius' answer - but thanks.)
Thanks, Dale
I don't know that it is the "correct" answer, Dale.  It is an option.
I suspect it falls flat when you have more than 9 components.
My test assembly only had 7.
You probably have to manipulate the rpt.index number in a new column to add a value to the index number.
That - I don't know how to do.  Hopefully someone does.
Dale_Rosema
(To:TomD.inPDX)
I was going by the fact that he had said thanks to you specifically. Thanks for the clarification.
JLG
(To:psimha)
Here's how I would do it:  I would create a BOM relation (repeat region relation) that adds 600 to the original index value, and then display the new value in the BOM:
The report parameters in this table are:
&rpt.index
&rpt.rel.NEWNUM
&asm.mbr.name
&rpt.qty
You can delete the first column after you get this going.
HTH
TomD.inPDX
17-Peridot
(To:JLG)
There you go!    I knew it could be done, just didn't know how exactly.  Thanks JLG!
