warp on assembly
Dom_CHENTRE
warp on assembly
Hi alls,
I'm wondering if it's possible (or ilt will be) to make a warp editing on an assembly.
If it's not, any trick to do this on assembly of few parts ?
Perhaps with relations ?
Thanks for any advices,
Dom
Chris3
20-Turquoise
(To:Dom_CHENTRE)
Do you care about retaining the individual components? If not you could export to a step and then import as a part (intf3d_in_as_part Yes) and do a warp on the imported part.
To my knowledge, no.  You could do as Christpher suggests.  I WISH you could do that or, preferrably, a spinal bend on an assembly at an upper assembly level.....
